Hi there,
I wonder if its safe to use the Nokia E7 while it is connected to the charger and the battery is already full, does E7 have an automatic sensor that it will use the chargers power supply or it will still use the battery and make it drain? Hope someone can enlighten me.
Thanks!
Jagger😊
I believe it will primarily use the battery, and refill the battery from the charger periodically. this is so when you pull the charger out, it doesn't cut power to the phone.
so I think the battery will get drained if I use my phone while on charge then... I heavily use 3G, and Nokia E7s batters is so poor 😞
