Calendar with MAC OSX
9 replies · 8,098 views · Started 06 April 2011
I downloaded the isync plug in and I get
"before you can synchronize your calendars, you need to open an calendar application that supports synchonization and create at least one writable Calendar"
So iSync will only do my Contacts, no Calendars?
So I set my Ovi Calendar to subscribe to my mobile me Calendar, and in Ovi.com all the events show up. But when I do a sync on my E7 the mobile me events in my ovi calendar do not show?
Any help would be great 😃
yes ical has plenty of events and previously i was using it to sync with my n900 via i sync.
Nokias isync plug in says it will sync calendars and contacts, so just trying to figure out what i have going on wrong?
OK, are your calendars "local" or only MobileMe subscribed ones? You need to have a locally defined calendar, even if there's nothing in it and you don't sync it!
Yes I do have the local calendar & not just the one online.
Nokia says their isyc plug in work with ical and will merge calendars.
I was doing this with my N900, but for my E7 I get an error.
Thank you Thank you!
Fixed..... I had to delete the calendar folder from my ~/library folder on my mac, but it did not take long to get all the appointments back in it, then I deleted my calendar on my E7 and it synced, nice!
So far not too bad with the E7, I am a little let down by some of the web browsing aspects, even with Opera, its slower than my N900. I have had to adjust some.
Hi there,
I own a Nokia E7. Isync works fine, I can import my calendar to my cellphone. But there's one problem:
In Ical i have multiple agendas, for example an agenda for work, for home, for holiday, and so on. When I import with Isync to my Nokia Phone, all of the agendas are put together on my Nokia phone. So all of the appointments are in my nokia-calendar, but there is no difference between a work-appointment or a home-appointment.
Do you have the same problem? How can I fixe this?
I tried to create multiple agenda in my Nokia-calendar, with the same name as in my Ical calendar, before I use Isync. It doesn't help.
Greets from Holland
@Sjaak78 I'm afraid there is no fix for this, all calendars end up in the one "PC Suite" calendar on the phone.
Damn!
When you sync a google-calendar or a microsoft calendar with a Nokia-agenda, the miltiple agenda stays intact? If so, then I first sync my Ical with google, and after that I sync the google-agenda with my Nokia?
Will it help?
