Nokia Pure Font
12 replies · 8,338 views · Started 09 April 2011
I have installed Nokia Pure Font on my N8 using the instructions on noknok.tv and I like it.
Only slight issue is that the digital screen saver clock numbers look a little bit blocky in places.
Anyone else tried it yet? Any other problems noted?
bazao wrote:I still don't know if I install it or I wait until April 12th... does it worth??
It does standardise the font across your phone, so if this is important to you, you have some spare time and you like to have a play with your phone - go for it.
Well... ok then. I decided to wait till April 12th. If no font are release, I'll install it by myself.
Have you guys noticed that restarting the phone connected by USB mess the Nokia Pure font hack?
Just tried it and you are right - restarting whilst connected via USB does make an unholy mess of the font, leaving most text missing!!!
Luckily a subsequent restart whilst not connected gets things back to normal, with the Pure Font displaying OK again.
I did have to remove then re-attach my ContactBOTS widget also.
monkeyandweasel wrote:Just tried it and you are right - restarting whilst connected via USB does make an unholy mess of the font, leaving most text missing!!!
I hate not having a real way to report this bugs to Nokia, cause in Conversations or Betalabs most of the time I finish talking alone... :S
warmth wrote:I hate not having a real way to report this bugs to Nokia, cause in Conversations or Betalabs most of the time I finish talking alone... :S
Maybe because it was not officially released (I mean, there is no support or news on its website other than the art gallery).
Since this s***y annoucement made me so disappointed, I tried Nokia Pure. NO THIRD-PARTY APP worked. Impressive, NO ONE! But it is really, reaaaaally an excellent font!!!
bazao wrote:Maybe because it was not officially released (I mean, there is no support or news on its website other than the art gallery).
In fact I am talking in general, not in this particular case of Nokia Pure... I know that it won't be support for something not officially released!
Something to be aware of: installing the Pure font via the "resource/font" method, can break some Qt apps. I found that Sleeping Screen (Nokia Beta Labs) and - more seriously - Ovi Store, no longer worked on my N8 once I implemented the font; once I deleted the font folder and its contents, the above apps worked again.
I reported this as a bug for Sleeping Screen, and from the replies, it seems to be a problem related to the current "stable" Qt runtime (3.7.1, I think). Apparently, installing the Qt 3.7.2 beta can solve the problem, but I understand this is not encouraged as it can break other applications on the device.
It's a shame, as I really liked Nokia Pure as my N8 system font - I suppose I'll just have to wait until things are fixed 🙄
Current stable version of Qt is 4.7.2. Nokia Pure works with this installed - I have installed this and Pure myself and find that everything works perfectly. Latest beta version of Qt is 4.7.3 which I now have on my N8 and can confirm Pure still works with it.
tawalker wrote:Something to be aware of: installing the Pure font via the "resource/font" method, can break some Qt apps. I found that Sleeping Screen (Nokia Beta Labs) and - more seriously - Ovi Store, no longer worked on my N8 once I implemented the font; once I deleted the font folder and its contents, the above apps worked again.
Thanks for the heads-up. I just checked and my Ovi Store no longer worked, so I have also now deleted the font folder and removed Pure.
A pity, but not the end of the world.
Am I brave enough to attempt to install the latest beta of Qt ...... hmmmm ......
