Cannot add a 'Meeting' entry on E63
1 replies · 6,506 views · Started 17 April 2011
Hello. For some reason, my E63 won't let me add a meeting via the calendar function. After I've filled in the details and press 'save', a dialoge box appears which says 'System Error'. The same happens when I try to add a new 'Memo'. I can however, add items to my 'things to do' list.
Also, when I connect the phone to my laptop via Nokia pc Suite, the calendar function fails to register and I cannot add a meeting via pc Suite either. Everything else (contacts, messages etc) can be accessed with no problem.
This is a recent thing: last week it was fine and I don't recall making any changes to the setup. I have the latest firmware but re-insalled in anyway. This has made no difference.
Anyone got any suggestions as to how I can fix this? Thanks. Glynn.
So, I've re-installed the latest firmware, done a factory reset, backed up my E63 to my laptop with PC Suite but without the 'settings box' checked then put this file back onto my phone and nothing and has solved the issue.
My phone won't let me do any commands such as #7780# nor will it let me completely format the phone using the green pick up key, no. 3 key and * key. Maybe that's something to do with 3 Mobile's software they put on the phone. It has been unlocked so that it will accept my Virgin Mobile SIM but there's still some 3 Mobile stuff on there which I can't get rid of.
Any suggestions or is the calendar funtion knackered? Thanks. Glynn
