The Weather for N8!
2 replies · 3,340 views · Started 18 April 2011
THE WEATHER
It is a simple application that allows keeping us informed about weather conditions, from our geographical location.
Allows you to select multiple locations.
You can select if the information we want in C � or F �.
It also lets you select the automatic update interval of our info.
And you can set up as Home-Widget!
you can download from Ovi'store!
Downloaded - good looking app, simple and functional
Much props for releasing a weather app with a widget, everyone else seems to forget the widget part (which I would have thought is one of the biggest aspects).
It would be nice if we could turn the GPS action off so that we could just set number 1 to be the default or something, as I prefer to do it like this because although it wont be 100% accurate to my position it's good enough and will drain less battery as it won't have to fire up the GPS everytime it refreshes (I hope that makes sense)
can anyone compare this to accuweather?
i like that accuweather gives temperature as well as a cannily accurate "real feel" based on wind and other factors, which really helps plan clothing for my daily cycle commute...
also, switching locations is manual and quick which is good to check the weather in my destinations, and switching between daily and hourly forecast is also helpful on accuweather (all accessible from a homescreen widget)
any comment on these functions would be welcome, as the above interface sure look purty! 😊
