My Nokia N97 mini has shows corupted file on music library and it cannot add any song. In my phone memory i have lots of song but it can't add to music library. The song file that contain in music library is deleted one by one. I need some sugggestion.
The music player shows corupted file and it canot add any song.
Hi there,
This worked for me. Have used this on N95 and N97 mini. havnt had to do it for a while. The files may be in a different place on th N97 mini. You may have to search for them. It works for music and podcasts. If you cant do it, you could put the music back in and delete it again.
* Firstly, connect your phone to a PC via USB.
* Choose Data Transfer (a.k.a. Mass Storage). Do not select PC Suite because you won’t be able to browse protected folders in PC Suite mode.
* Open Windows Explorer on your PC.
* Go to \private\101FFC31 on the phone’s folder.
* There, you should be able to find the mpxv1.mpd (for MP3) and pcv5.mpd (for AUDIO PODCAST)
* Goto \private\101f8857\Cache
* Goto \private\101ffca9
* In all the 3 folders delete all the files Not the FOLDER
* Now refresh ur music library
Hello
I tried this method as you explained :
I went to E: and F: drive on my N97 mini and erased any file there but it does not work. I still have this "corrupted file" error when I want to see all my music files in the music application ... On both cards, I found the private folder and did as explained.
I guess that my N97 mini still have the music list with a problematic name inside somewhere else ?
any help on this, would be welcomed ! thanks in advance...
Is there a way to reset the "music" application ?
