Hi.
I�m having some problems on my Nokia C6.
I can�t run the Polarbit games, they just don�t work when i click.
I've been reading about this problem, and so i found that is a "common problem" is some Symbian cell phones.
So i found the problem's resolution: Modify the "ngi3devcap_0_9" file on the c: folder, using the Y-browser (I've already downloaded the modified archive).
SOme people have done this with success, but i can�t!
When i try to replace the original ngi3devcap_0_9 for the modified ngi3devcap_0_9 file, a error happens!
I tried to modify another archive in the same folder, but i can�t modify ANY file in the "Resource" folder! So this is my question: Is there any other way to replace this file?
Maybe there is a PC Program which i can explore the C6 files and "force" the replacement of this file... Or some other way to do this.
Ps. I hope you understand my text, i'm not american, my english is not so good :P
