E71 charger doesn't plug
1 replies · 7,418 views · Started 28 April 2011
my E71 housing was very damaged and i bought a new original nokia housing and reassembled the whole cellphone. Everything is working smoothly except the charging system. When i try to connect the charger into the cellphone it doesn't connect and it seems that there's no socket to connect the charger pin.
Someone could tell me how the charging system parts look like?
Hey buddy….I too bought an E71 housing few days back. I bought an original Nokia housing from my nearby Nokia care. It some what looked similar to my phone and everything worked very well with it. If your charger doesn’t connect into the cell phone, I think you have brought a wrong housing. The chances are that it may be the housing of some other E series phone. I was searching for some sla prototype designs. Please go to a nearby Nokia care and make sure that it’s the right housing you have brought.
