hello all, i suspect the qt libraries are messed up. if i do a fresh reinstall using ovi suite will this sort it or should i just reinstall the libraries? thx
social and battery monitor not working
Since it's just two qt apps I would recommend reinstalling the qt libraries first. That could save you some headache if it solves it without having to do a full restore.
