Hello,
Last week i get n97 mini /second hand/. I realise that on my device there is installed some kind of phone guardian...the phone works, but the program works in background, which is not good for battery life...also it get bugs and lags...phone restart itself...I want to uninstall it, but - i can't find it to do that! I try factory settings and update the software, but program is still on my device....Please help me, how to remove it? Thank you.
N97 mini problem
Go into -settings-Application Mgr-Installed Apps and look for the prog there. If you can find it delete it. last resort do a hard reset and re- format E: Mass Memory and start again. Good practice with a used phone that should get rid of any un-wanted rubbish form the previous owner and make it yours. Google 'Hard reset N97 mini'
