N8 app manager broken?
5 replies · 7,021 views · Started 16 May 2011
When I go in to the app manager view I only see a fraction of the installed apps. The others do not show even though they are installed. Also since about a week ago I cannot install any apps, I always get an erreur message on the Ovi Store.
Will I have to follow David Gilsons advice about when beta apps go wrong?
Martin
Right now that I have the "Unable to install(-1)" error appearing each time I wanna install something my app manager ain't displaying all my apps so I can uninstall some apps that could be making the problem to test.
You should not restore from backup on your mail for exchange - rather let it resync it all again from the server because it does not restore the configuration properly and screws it up. I've learnt my lesson before and ended up with a hard reset for it all.
