moving games in apps folder to games folder?
5 replies · 7,946 views · Started 01 April 2003
when i install *.jar games to the MMC/phone,it will be saved in the apps. folder and can't be move to the games folder. Anyone knows where to find the associated *.jar files and move to the games folder ?
use "games installer" instead of "application installer" when you install the games file 😊
kireina wrote:use "games installer" instead of "application installer" when you install the games file 😊
How do u do that?
There is no "games installer". On Series 60 1.2 phones with MIDP 1.0 support, all Java midlets are installed in "Apps" and cannot be moved.
With Series 60 2.0 and MIDP 2.0 (the Nokia 6600 and newer phones), they appear in the menu just like native Symbian apps.
