How do i download the sound of my standard ringtone from my e71?
i cannot locate the files despite browsing with the nokia software the data folder of the phone?
any tips how to do this?
It is not very difficult .
Install X-Plore from http://www.lonelycatgames.com/?app=xplore , using Web or Opera Mini Browser on your device .
Take the "everlasting" trial .
X-Plore has some learning curve , but after some time you'll find out it's great .
Via X-Plore's Menu open ROM drive = Z:
For all different sounds in Z: , go to :
1) data > sounds
2) system > apps > Barcodereader ( if existent )
3) system > apps > sounds
On qwerty :
When you want to copy a file , you can press 'space' button to mark , following by pressing button 'C' to copy to memorycard ( E: ) or the device memory ( C: )
By pressing the 'Green' button you can Bluetooth the file to another device .
A message in 'Messaging Inbox' can be transferred to another location by pressing button 'X' to view the message ( or file ) , press 'space' to mark and press button 'M' to move .
Anyway a great , multifunctional Filebrowser .
X-Plore it yourself !
😊 Regards jApi NL
thanks, it works a treat.
i really appreciate it!
