Pin2 code
2 replies · 4,979 views · Started 08 June 2011
Hello
Can anyone help me understand how the PIN2 code works?
I used up the 3 trys for the PIN2 code and got a message that I needed the PUK2 code to unblock the device. I found the PUK2 code that I had stored previously in Handy Safe ages ago and entered the code. Then I get asked to to enter a New PIN2 code and following that enter the same numbers again to verify. And that's the problem, each time I enter the numbers the second time to verify the code the phone says Error!!!! It's this that got me into the mess in the first place.
Martin
I need a console app in symbian which can run in background and capture the green key.Please suggest the ideas and source code if possible as i am new to symbian .....Thanks in advance
