T-Fileman is a file browser special designed for symbian^3 system mobile, such as Nokia N8, E7, C6, C7, E6 and X7
T-Fileman show file/folders in Tree view and List view, that make it very easy and clear to browser and operate on files.Well designed buttons speed your operation.
The feature of T-Fileman is use dobule views, Treeview and ListView. Treeview show the tree structure of the file system, while the Listview show all contents of the current folder. It's same as the design of the Microsoft's Resource Manager.
Just try it! It's free full function trail for 30 days.
Free Trail version.
Feature List:
Features:
* Tree view and List view, fast switch between them
* Well designed buttons operation
* Fileman operation:
o Copy/Move/Delete files/folders
o Rename files/folders
o Search files ( * for wildcard search)
o Shortcut create to Shortcut folder
o Mark/Mark all
o Attribution change of file/folder
o Sort files/folders in size, date or name
o Display or not the hidden file
o Display or not the system driver
o Show detail information of selected files/folders
o Show image thumbnail(jpe/gif)
o Run/open files in application
* 3 more skins beside the system one
Free Trail version.
More shortcuts:
Please visit Kenvast Software for more detail.
Review: T-Fileman vs X-plore
http://mobile.allaboutsymbian.com/reviews/item/12986_T-Fileman_vs_X-plore.php
installs and works well on N8.
30day demo 😊
Reply to #3:
"Review: T-Fileman vs X-plore
http://mobile.allaboutsymbian.com/re...vs_X-plore.php
Regards jApi NL "
Thanks Steve for this review. But here are some points on T-Fileman are ignored in the review. From the brief guide picture in #1, you can see something.
The feature of T-Fileman is use dobule views, Treeview and ListView. Treeview show the tree structure of the file system, while the Listview show all contents of the current folder. It's same as the design of the Microsoft's Resource Manager. "blue double headed arrow" are used to stwich between them. Use 2 views is the biggest difference with x-plore. The advantages are:
1. when there are many files in one folder, it will be clear to operation on them in the list view.
2. you can mark all contents in one folder with just one option menu: Mark All
To search file, please add * for wild cast search.
BTW, T-Fileman is built with pure symbian c++, not QT.
X-plore is almost the STANDARD of the fileman on Nokia phone. Kenvast's T-Fileman just wants do something more on touch screen mobile to take the advantages of the touch screen as much as possible. The application is published only for Symbian ^3 mobiles.
(Since the OS bug, the tree view is not run well for symbian E5 mobile such as N97, N5800, X6 etc. But if you like, s60 E5 user can just use the listview, its a full function file manager too, with much more touch screen featured file operations. )
Find detail on Kenvast Software website:
http://www.kenvast.com/T-Fileman.htm
@Kenvast
Post your comment also in the Review's Comments . Or post at least a link to this Forum thread , as Steve might not read the Forum .
😊 Regards jApi NL
jApi NL wrote:@Kenvast
Post your comment also in the Review's Comments . Or post at least a link to this Forum thread , as Steve might not read the Forum .😊 Regards jApi NL
Thank you jApi NL, these comments are already in the Review's Comments 😊
