irRemote v. 0.90B NOW!
56 replies · 6,474 views · Started 03 April 2003
Go and get it while its still hot 😃
Supported remotes:
Admiral, Aiwa, Akai, Allsat, Anitech, Apex, Aristona, Avex, Barco, Blaupunkt, Bush, CCE, Crown, Daewoo, Denon, Elemis, Elitron, Galaxis, GoldStar, Grundig, Hitachi, ITT-Nokia, JVC, Kenwood, LG, Lifetec, Loewe, Magnavox, Manhattan, Marantz, Mark, Meliconi, Mitsubishi, Nec, Nokia, Orava, Panasonic, Philips, Pioneer, Portland, Rubin, Samsung, Salora, Sanyo, Schneider, SEG, Sharp, Sony, Technics, TechniSat, Tesla, Thomson, Toshiba, Universum, Watson, Yamaha, Zenith
Dont think it needs any more info 😃
Get trial from here:
http://www.psiloc.com/nokia/eng/irremoteS60/index.html
Version 0.90B
Size on disk: 270 kB
i got:
App. closed
irRemote
DBMS-Table 0
on 4.36
Sure PsiLoc will be swamped but I emailed jsut incase their not heh 😊 Simple online bugtraq would be nice.
really must go bed now.
[quote="evobit"]any idea why phone needs to be restarted after the install?[/quote]
I think its not neccessary. (atleast on my phone it isnt) Just playing it safe.
[quote="guytp"]i got:
App. closed
irRemote
DBMS-Table 0
on 4.36
[/quote]
Whoops, same for me, 4.39.
MGS 1.90
Video Recorder 3.04
irRemote 0.90
IM+ 2.14
Beumused 1.21
Tetrix (for MGS) 1.00
PsiNT eLib 1.76
apps:
PuzzleBobble
ReptonDemo
I'm on f/w 4.39, installed correctly, didn't need to restart, and worked (on & off) on a Philips TV (it looks like a poor quality philips, I'm in a hotel :cry: )
wait & see how it performs with the bits&pieces at home 😃
Paul
Never had wildskinz installed.
Currently:
Stacker 3.0
Handybook
FExplorer 1.07
MGS 1.9 (no games)
Photographer 2.0
Apps:
puzzlebobble
PB or MGS Id go for then or total fluke I dont have PB original anywhere and probably lost MGS too :P lol lets just hope a fix comes :'(
We'll I'll remove MGS and see what happens.
BTW, you can dl mgs from their website for free, just need to register the individual games.
I don't really want to reset my pb highscore (87000) hehehe
And it cant be PB as the java apps/games dont have anything to do with
the rest of the system. I havent had MGS installed ever.
I tried again and before installing the new version, deleted the old completely.
Works fine.
Ps. Do you have any apps running in the background? Keylock or some other.
Dang, removed MGS and still the same error, even reinstalled irRemote and still no luck. GRR. I'm going to try an earlier version of irRemote, then install the new vers over the top...
Jyrik, question..
What file does irRemote0.3 leave behind when I uninstall from AppManager? because I just reloaded it and it has kept the settings from last time it was installed.
Could it be irremote.dat on C:/system/data/
But i have always lost the settings when installing a new version :-?
Strange. Now I go and get some sleep.
Worked for me to... the following is my experience of it.
Great idea.
Fantastic design.
but...
When I try and use "BUSH TV" I get App. closed irRemote KERN-EXEC 3. Anyone else get this when trying Bush TV's - works for all other stuff.
I know learning has been discussed on other threads but I have a 400 disc CD changer so the 1-5 options arent really that useful 😊 + for the record i seem to have about a 3cm range on a sony CD player!
No minidisc support for Technics.
No DVD support for LG.
I just thought I'd whack it on incase anyone cares.
Guy
[quote="Devilish"]Does it/Will it provide support for the playststion 2??[/quote]
Not yet. But I understand, that support for it is coming.
Doesn't work on my Panasonic CD player.
Doesn't work on Grundig TV (well, it does take one command, after that it stops working).
Works on JVC VCR (well, recording doesn't work. Nor do the play functions) ... range 1 metre.
is there any way to download it over the air as i havent got any data cable for phone or a USB socket on my PC!
if not, could someone please email it to my phone if possible so i can download and install off my POP3.
my email address is [email protected]
thanks
doesnt work on my sony wega widescreen tv
works on everything else i tried though😊
