Hello there,
I own a Nokia E7-00 (Symbian Belle) and a Samsung Galaxy Tablet 10.1 with Android 3.2
My problem is: Although I installed Joikuspot Premium correctly to my cellphone, my tablet can't find it when Joikuspot is enabled and the tablet is searching for networks through wifi...
Is this problem known by one of you and is there a (simple) solution for this problem?
Many thanks in advance.
Peter (the Netherlands)
Android (3.2), probably, doesn't support ad-hoc hotspots.
N/A wrote:Android (3.2), probably, doesn't support ad-hoc hotspots.
Android doesn't support ad-hoc out of the box ..
the generally accepted answer is found here http://szym.net/2010/12/adhoc-wifi-in-android/
Good luck!
there are a few apps on the market too that might help... requires root tho. 😊
On your Android Tablet Download BlueVPN (its free). it will enable the DUN protocol on your Android tablet, and enable tethering via Bluetooth pairing with almost any Nokia phone. Won't work with Android or IPhown as there bimplimentation is SHIT.
Search for GPRS settings for your network, and enter it in BlueVPN.
Good Luck. 😊
