Nokia 700 Low Memory on C: Problem
5 replies · 12,410 views · Started 18 September 2012
My wife has a 700 which after 9 months or so developed a problem. Texts getting stuck in outbox, not receiving calls, etc. It also showed the "Memory Low: Remove some files from C:" message from time to time.
Before sending the phone back, I did a factory reset of the phone and restored contacts, apps, etc. (My wife only has about 3 apps on the phone anyway so this was easy enough.)
The phone worked well again. However, it prompted for an update after a week or so. (Nokia Maps, Microsoft Apps and Nokia Social IIRC.)
After updating we're back to the memory message and associated problems.
Anyone any idea what's happening? Is there a problem with one of the apps or is it the phone? Is there any easy way to clean up C:?
trbarrett wrote:My wife has a 700 which after 9 months or so developed a problem. Texts getting stuck in outbox, not receiving calls, etc. It also showed the "Memory Low: Remove some files from C:" message from time to time.
sir the microsoft app update is the prob.... the same thing happend to my N8, since i downloaded the microsoft update my phone shows the same error memory low... and the worst part is the microsoft app after uninstallation the app still shows in the main menu...
Thank you, I think SONY Ericsson mobile phone shell this nice, very smooth and give the first eye is very high, the way to ensure comfortable feel, not changeful form, to avoid the loss of characteristics to let everyone like
There are a lot of users are often in charge when the phone is open, in fact this will be very easy to damage the mobile life, because in the charging process, mobile phone circuit board will fever, at this time if there is foreign phone, may produce instant return current of mobile phone, internal damage parts.
