Beginning to love my new 808 a little less now.
I am finding it impossible to connect to my wireless router.
I scan for WLANs and see my Router.
I try to connect and it says "Select network supports easy setup for receiving settings. Configure now?". Never seen this before, if I say "yes" it asks me to press a button on the router. There's a WPS buton on the device and I push it. It says "Configuring connection settings" ... for ages. Then stops saying cannot configure connection.
NO LUCK.
So I try to connect the old way and select No to the easy setup. It asks for a password. I give it and the it says "Connecting..." for a few seconds and them the router drops back to UNknown. No conection.
NO LUCK THIS WAY EITHER.
I have had numerouse devices connected to the router in the past so it cannot be at fault.
Any ideas?
I am using Belle FP2.
