any1 find after having the 7650 for a long time the sliding function is too loose?????
any solutions???
any solutions???
Yes me...solution: New housing!
[quote="MaleBuffy"]Yes me...solution: New housing![/quote]
Yip only thing that worked for me
is it hard to change??
Actually,no,you got to the nearest NSC and they change it for you 😃
They've told me it costs less than 30 euros in Greece, but I am still worried if they can... put it back together! :P So I haven't taken it there yet!
I had a very solid slider that wasn't loose at all... then the fone totally died (wouldn't charge) and they replaced the slider unit when it came back (3 weeks later) it didn't feel half as solid as before.
[quote="petran"]They've told me it costs less than 30 euros in Greece, but I am still worried if they can... put it back together! :P So I haven't taken it there yet![/quote]
I did....I am sure they can! 😃
[quote="MaleBuffy"][quote="petran"]They've told me it costs less than 30 euros in Greece, but I am still worried if they can... put it back together! :P So I haven't taken it there yet![/quote]
I did....I am sure they can! 😃[/quote]At 220 Syngrou Ave? I may take it there next week... I may take my chances. A friend who had his repaired there a few months ago , had problems due to bad re-assembly and took it back again! 😞
One month ago, My service changed my both front and back cover in warranty!!
Then problem was solved.
And also they changed my battery in warranty!
For your informations...
so there ıs no way of fixing it at home.
