Worldmate???
2 replies · 1,530 views · Started 05 April 2003
Hey guys, having trouble installing worldmate, im able toput it on the phone no prob, but when i try to open it to install, its telling me that i dont have a suitable "viewer" to open the file!!!!
Is there another program i need installed to be able to run this???
Many thanks in advance
Matt
Thats strange? I didnt encounter any problem installing it. Its a sis file. You dont need any other software for it
😃 Well i believe u are trying to install the .EXE file of WORLDMATE...
connect your PC SUITE and install it from your PC...
:P Good Luck!!!
