Handy shortcuts...
4 replies · 2,056 views · Started 07 April 2003
You may all know this, but I just found these out at the weekend while having a play.
Pressing and holding C will toggle silent mode,
Pressing and holding app list will bring up the applications menu rather than the context menu
Pressing and holding OK will make it listen for the voice command.
Pressing and holding any number will take you into contacts for the relevant letter (3=D etc).
Like I said, these may be well known already but they're very handy!
Cheers
Jamie
[quote="Jamester"]You may all know this, but I just found these out at the weekend while having a play.
Cheers
Jamie[/quote]
I know about the numbers taking you to the contacts, but I didnt know the others! 😊 Cool Tips!! 😊
Also you can press and hold jog wheel in to activate voice dail and you can also press the jog whee in to take pics with flip closed, good if like me you are left handed
