firmware upgrade
7 replies · 2,133 views · Started 09 April 2003
Hi
anyone know how can I upgrdae my nokia 7650 firmware by myself ?
where can I find the last firmware ?
thank tou
Well,you need a DTC 4 flasher box(I think that its really expensive).
I dont know where you can find the latest firmware.
[quote="Msx"]Hi
thank tou[/quote]
If You get a flashbox (Pretty Pricey) I think Nokia is the only ones with the actual firmware.
Easiest is to go to a Nokia service Center. They upgrade for free or for a nominal fee
[quote="Msx"]Thank you (GhostDog),(Doc)
I was think its easy to do upgrade[/quote]
Yes the biggest problem with upgrading is that very few places do it while you wait. It normally means leaving the phone for a few days or even a few weeks if it can't be done on site :x
Yep, if you have a choice of several NSCs nearby, check them to see what version of the f/w they have, and if they are prepared to do it "while you wait" (that in itself is a good indication of their ability).
Your phone should be under warranty, so you can just say the phone hangs a lot, you need to reboot several times a day, that way they should do it for nothing.
As Doc & GhostDog have said, the flasher itself is about �150, not sure if you need anything other hardware, and then you have to find the firmware (not for sale!!!).
I upgraded "while you wait" it took just on an hour from start to finish. Easily the safest option
Paul
How can i find out what version of firmware is my phone running?Or should i assume it is running v3.19 since i didn't upgrade to a higher version?
[quote="@gr"]How can i find out what version of firmware is my phone running?Or should i assume it is running v3.19 since i didn't upgrade to a higher version?[/quote]At the stand by screen, type: *#0000#
