128mb memory cards
10 replies · 2,489 views · Started 28 May 2002
WOW,
I've just found out that you can get 128mb cards for the 9210 from timscali.
But before I order a few of these, has anyone ever ordered from this company before?
What are they like, how long does it take for the cards to arrive?
Any advice would be most appreciated.
I ordered one 128 MB from them and I live in The Netherlands (Holland) and it took about 2 weeks to arrive.
So you can order it safely. The company is ok and the 128MB MMC simply rules! User posted image
i live in india & it took me less than a week to get mine. So be rest assured...its a good & safe company to order from.
Go ahead & dont wkorry,.
ciao
HyPeR
Can anybody give me the url where I can order them from? I've been searching for the 128 mmc, but it seems no store in whole belgium/Netherlands has them. /
Hi everyone!!
Since I have been thinking about ordering a 128MB mmc myself I asked Club Nokia in Germany if they could tell me whether these cards work and can be handled from my 9210.
And they said I should go forward buying one, because they are working and safe!!
So there are no problems in the pipeline,
Greets,
Ralf
Hi. Has anyone tried using a 128 MB Secure Digital Card instead on the 9210? The 128 MB MMC is alot more expensive than the SD and these are used by the Palm. Hope someone can try.
SD cards are slightly thicker and don't fit in the MMC Slot. Furthermore the connections differ!
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote</font><HR></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
Yeah your 100% right, the SD cards are to thick and won't fit in the 9210 unless forced!
