FileExplorer 1.08 final
20 replies · 4,209 views · Started 11 April 2003
Just some words to say that FileExplorer v1.08 is released !!
please, visit www.gosymbian.com for screenshots, download link, ...
thanks to all of you for beta-testing !!
Domi.
PS: can a moderator write something in the 'Nokia 7650 / Series 60 News Headlines' to introduce this new version - Thx.
what's new in version 1.08 :
* added a menu : network information
* in the 'file menu', it's now possible to set a picture as
an operator logo (last point of the menu); jpg and gif are
resized, bmp none.
* a 'settings menu' has been added that allows to configure
FExlp. (the settings are saved); you can set up the color
in list, the display of the full path in full screen mode
the full screen mode.
* a confirmation dialog is showed before quitting the pgm
* the restart function has a confirmation message
* it's possible to edit (in fact view) the files
(like ini...)
* the size of the files are displayed on each line and the
font is smaller to display more character.
Just tested fexplorer on my N3650 (firmware 2.50). Nice software BUT there is a problem:
It does not show the file size!
In drive view it shows in a legible but small font 'ram' or 'rom' at the end of each line. This font has serifs.
In file or directory view nothing is shown at the end of the line (�hhh to be exact: there seems to be a little point or something else - at least nothing legible).
Empty lines at the screen (no file, dir or drivename) show a vertical line...
Could this be a font or string-formatting related problem??
Dieter
Addendum: These little unlegible points show up only when I use the english version of fexplores on N3650 using german language and the file size is to be given in KB (instead of B). With both using english language these points cannot be seen.
Filesize is not shown in this configuration, too.
Weared.
Dieter,
I have no 3650 to test it !! sorry, I only own a 7650 but, can you send me some screenshots of the problem ?
I will be very happy to find a solution for the 3650 users !!!
PS : the vertical line showed when a part of the screen is empty is normal, I haven't found how to solve it !!!!
PS2 : the font used for 'ram' 'rom' and the file size is the same.
Thanks,
Domi.
[email protected]
[quote="Domi"]Dieter,
Thanks,
Domi.
[email protected][/quote]
Hey, I am flattened by Your quick respose. I will produce some pics this evening ( will have to go shopping now) and send them to you via PM - I think posting here won't be right.
Dieter
No problem Dieter,
but don't expect to receive an answer before monday, I'm leaving this week-end and I have no internet connection !
If you want, you can send the files directly to [email protected]
Domi.
great work domi!!!! keep up the good work man!!! thanks for the function "set as operator logo"! love it! 😃
I played a little with the fexplorer and foud a little problem. When I try to edit a txt file or somethin I can only write numbers in it. But no words
Is it possible to fixt hat, or is it just a bug in my version?
Greetings, tias
Hi Tias,
It's not a bug because, in fact, in this version, it's only a viewer, you can't saved modify files, thus no need to use the alphabetic or numeric keys.
Domi.
Hi Domi,
Excuse my poor english speaking. I'm writting to congratulate you for your work and also make few suggestions :
* Getting back from viewing a file returns to the root of the phone (C/D/Z)
better if it returns on the file recently viewed (edited)
* Why there's nio icons for files (known/unknown)
* A french version ????
For the rest, IT'S A GREAT WORK. CONTINUE...
Hi Samir (and all the others ...)
Thanks a lot for your congratulations !
I put your request in my todo list - your are the second in one hour to ask the return to the previous directory after viewing a file !! I'm working on it, of course.
there is no icon because ... I haven't program it !!!; I must still do it ! I have prefered spend some time in functions instead of cosmetic !
a french version ... in fact, ... I'm french !!! and never released a french version because ... you (Samir) are the first one to ask me FileExplorer in french !! but now, I must think to release it !!
Domi.
Hi Dom,
I was just wondering,how do I get back the original operator logo? Thks.
P.S. GREAT job.. ;o)
-Jay-
i'm using firmware v4.39
1) the font should be smaller?
in the left column (name) everything is ok, but in the right one...
2) when editing a file the "Please wait!" Dialog opens min 10 times at a different position... with every opened window the line wents up 1 line
3) ! when editing a file only numbers can be entered??? cant switch with "#" (long or short), not with "ABC"... *?*
-> oh i see... no editing just viewing... sorry 😊
but editing would be nice too 😉
thx
walter
Hello,
to get back to the original op logo, just go to c:\system\apps\phone\oplogo and delete the file in this directory (there is no 'automatic' function)
for the font, I'm working on it (and for the 3650 too), I'm working on the Nk7650 version 3.16 -- I have not all the versions of the OS --
Walter, can you send me your e-mail address at [email protected] ; whenever I have corrected the font problem, I can maybe send a version to you for testing (OK ?)
Thanks -
Domi.
Domi did it again. He solved the Font-Problem and it looks much better now.
Thanks for your quick support.
Walter
As a suggestion; maybe remove the "FE" from the icon? It looks sort of "cut off" if you know what I mean?
As for that line down the side.. I'm still yet to get that on my 3650 😞
