Files on 7650
4 replies · 1,582 views · Started 11 April 2003
Ive sent a .dll file throught BT to my 7650 but i can only get it either in the inbox or my folder dir, how can i move it to c:\system\libs ??? Can anyone help me, please???
Cheers!
Use FileExplorer to do that (copy/move/delete files and more)
and it's free !!!!
more info : www.gosymbian.com
Hope this help ....
Domi.
[quote="yourmanlee"]Wow Domi. You should really be in marketing!! 😉
Lee[/quote]
No Domi is a Saint. He gives away one of the best applications for the 7650 😃
yep, File Explorer is great! All the same, be careful about using dll files like that. To guarantee system stability, it's best to leave the dll files as created from the program install. Or uninstall & reinstall the program.
Paul
