New version of PC-Remote (1.8)
15 replies · 3,213 views · Started 13 April 2003
http://www.i.am.so.sorry.admin/
Size: 247 KB (252�076 bytes)
Size on phone: 32 KB
Recommed that you send the .sis-file to the phone via bt or ir.
Allows you to use Winamp, DScaler, MediaPlayer, WinDVD, PowerPoint and WinDVBLive from your phone (via BT).
Other functions:
-Mouse moving
-PC mute
-PC volume
-PC shutdown
-Time (on PC screen)
Changes to 1.8:
-Added support for WinDVBLive (TV) software
-New ini-file structure
Languages:
-English
-German
-Turkish
-Portuguese
-Swedish
Did you send the sis-file to your phone?
You probably tryed install it whit PC-Suite.
Sorry not logged in - on wap - i did install with sis and pc - the error i got said my phone wasnt compatible?
[quote="Anonymous"]Sorry not logged in - on wap - i did install with sis and pc - the error i got said my phone wasnt compatible?[/quote]
Yes, the phone said same thing to me, too.
Installation asks you about: "...phone is incompatible... Do you want to quit installation? Yes / No" Did you press "No" when this notification shows up?
Admins, can I ask why link is removed? Just curious 😮
Direct links to software is not permitted (even if the program is trial,shareware,freeware) unless you have the permission of the developer. Legal stuff and precautions to keep AAS as it is now...
Yeah, links to websites are ok, but not links to files... There was a discussion about that previously. You may find it he you search a little...
It was only link to the web-site, not direct link to the file. 😞
First I had both links (web and file), about 30s , but then I rememberd thats its forbidden.
So maybe admin saw direct link to the file and same time I edited it and right after that the admin edited the post (accidently).
Or then I removed wrong link and there was only direct link to the file 😮ops: Only other forum-folks can say it... becaus I don't remember it...
Anyway sorry if that was my mistake... I'm soooo crazy :silly: :crazyeyes: that I make mistakes over her
The only other reason that the mod would remove the link would be the site containing warez or having links to warez site. Or maybe as you said he was confused. Anyway i don't know i wasn't there. You may try to re post the link if you feel it is legal...
This one finally works fine except for the mouse. When I control the mouse with the 7650 joypad it keeps moving until I point it to another direction. Anyone is experiencing this problem too?
[quote="MemphisX"]The only other reason that the mod would remove the link would be the site containing warez or having links to warez site. Or maybe as you said he was confused. Anyway i don't know i wasn't there. You may try to re post the link if you feel it is legal...[/quote]
No! There is no warez in the site, it's only this prog's homepage.
I pm you the link that you can check it out.
[quote="deathmonger"]This one finally works fine except for the mouse. When I control the mouse with the 7650 joypad it keeps moving until I point it to another direction. Anyone is experiencing this problem too?[/quote]
It's property that the mouse keeps moving. When you re-press that direction where you just pressed, mouse stops.
In earlier version you had to keep pressing that direction where you wanted the cursor move... it was very annoying. The new system is much better.
Ok here is the link Urpo posted
http://www.pc-remote.de.vu/
I take full responsibility if this whole thing is ilegal. I would just want from the moderator to explain if it's going to remove it.
PS1:Thanks Urpo...
PS2:WOW 600 posts and still counting
[quote="Urpo"]No problem, I think 😉
Congratulations! 😃 I only have 120+ posts 😉[/quote]
Thanks again pal. You know after the pop you can't stop... OH no that's from somewher else...
:angel: After the first post you can't stop :angel:
