I have read through all the 3650 forum and still there are some unanswered questions.
Q1: What is the maximum MMC card compatible for the Nokia 3650, 128mb or 256mb??
Q2: What is the maximum seconds that you can record using the HIPCAM, i do not care about the file size limit. The duration time plz.
Q3: Where is the best web site to get the latest games and applications for the 3650?
Q4: How can you take all data off your old MMC and transfer it to your new MMC?
Q5: Will the 3650 ever have radio cababilities?
Q6: Will sonic ever be availabe for the 3650?
Q7: Can you assign an MP3 as a ringtone? If so how and with what software application?
Q8: How can you transfer via IR large amount of data as the phone memory cannot cope with the file size.
Q9: Will the 3650 ever have an 8 way navigation compatability like the 7650?
Q10: How can you send ringtones through the 3650 to another mobile?
Q11: I have heard the 3650 is mono and not stereo, is this true?? If true will it be possible in the future to switch from mono to stereo?
Q12: What is the best compressing tool?
Q13: Is it possible to move JAVA games in the APPS folder into the Games folder? If so, how?
Q14: Is it possible to make ringtones louder?
Answering these question will definetly prove helpful to me and others.
Thanks for your time to read this topic.
introlux :agrue:
