Quickpoint
2 replies · 1,856 views · Started 16 April 2003
Has anyone had any success with this? I've not been able to get an install working and keep getting stupid errors - its looking for a palm directory & comes up with 'can't find userdata' whenever i try and load any part of it.
have tried their support but don't appear to be responsive (or care?)- pity cos it could be a v useful litte app.
I had it working some time back, the plug-in within Powerpoint converts a ppt into a prc file, then you have to transfer it over to your phone (occupies about 10% of original file size). I didn't have any problems installing the programs or opening the files, although the 7650 screen is just too small to read the slides. There is a zoom feature, but you lose control of the context (I couldnt move up or down the slide).
Also for me, another hassle is that you have to convert the ppt yourself (or somebody else who has gone to the trouble of installing the plug-in), so you can only view presentations from your computer.
Nice idea, but didn't convince me. I'd be happier with a xls/pdf/doc viewer (email viewer already supports pdf/doc attaches and does a good job of it too).
Paul
Agreed.
No problems installing it initally. But this app didn't do it for me either. Too much hassle and messing around. OK if you're going to use it a lot i suppose.
Lee
