What fast method are you using to restart the phone? I see many programs that has restart function but this is slow. i must exe program, then menu and restart. fuck this
i need some fastest restart. etc on OFF button - add in menu (with profiles and off telephone and key locked) restrart function. exist this soft?
or exist some hotkey or keyshortcut for restart?
btw: i dont need soft, that is everytime loaded in memory - this soft suxxx.
I think RESTART takes its time. No matter how you do it. Think of what the phone goes trough wile reSTARTS.
What should bother you, is the amount of battery it takes! It's like a Ferrari 😃 If I restart 3 or 4 times it consumes half the battery aprox. 😞
Well for of the faster way to restart the phone is by psiloc's task manager. If it is installed by just keep pressing the menu key the prog comes out then left key tools and restart. That's the fastest way for me...
yes but task manager is loaded in memory.
i used many programs (miniGPS, eProfiles, sProfiles, eAlarm, scrSaver,...) but now i hate this programs because this programs using batery for whole time and i then have little memory and slowly system.
Should we make modifications to the firmware for you to have this option on the power menu? (translation:YOU ARE ASKING TOO MUCH)
i sent to Nokia one mail with this request to adding restart function on OFF button 😊
i doubt it'll happen since RESET is more of a 'advanced function' rather than something every little kid should play with.
