z drive
8 replies · 2,618 views · Started 09 June 2002
hello. i just got my phone upgraded to 4.13 version. problem is, my z drive disappeared from the file manager, and i forgot how to bring it back w/ the key presses. can anyone help me. what are the key presses again. help! thanks.
Thanks man. I couldn't remember all these key presses since there are soooo many of them to remember. Its well appreciatted. User posted image
Im not quite happy w/ what Nokia center did w/ my phone when they upgraded it to 4.13. Some applications were duplicated since they reinstalled some appl to my c drive, when in fact i have those appl in my d drive.
Now, i plan to reinstall them myself. Just wanna ask if i do need to format my c and d drive first before i reinstall all data .sis memory card & c (from nokia product support), or there's no need at all. I can just proceed w/ the reinstallation directed all to my d drive? many thanks.
Just a correction.
Press Shift/Ctrl/K and Set show system directory to No.
[quote="renejohanna"]In filemanager press ++sp. After that Shift/Ctrl/K. Set show ROM to yes[/quote] Set show system directory to Yes. Now, exit File Manager and start it up again.
For my system, pressing ++sp, while "Show system directory" was set to Yes, did not do anything.
[quote="apcaw"]Im not quite happy w/ what Nokia center did w/ my phone when they upgraded it to 4.13. Some applications were duplicated since they reinstalled some appl to my c drive, when in fact i have those appl in my d drive.
<BR>Now, i plan to reinstall them myself. Just wanna ask if i do need to format my c and d drive first before i reinstall all data .sis memory card & c (from nokia product support), or there's no need at all. I can just proceed w/ the reinstallation directed all to my d drive? many thanks. [/quote]
Oh Yes, that would of course be better if u format and re-install everything...
Just remember:
1. to install the right stuff... the one for 4.13.
2. Back up your CONTACTS... u dont wanna loose it... 😉
Mannn .. its a half an hour game !
backup every data which you dont wanna lose eg contacts/mails etc (excluding half hour :angel: )
Format the device either via PC suite or before boot press shift+Ctrl+f
Then Install that All_Nokia_9210_data_v413.sis file simply
Thats it ! plz pay 50% of the money you paid to nokia for that advice 8)
how to change or edit the files on the z: drive like the shake hand ont he first time 9210 running i want to change it but it shows read only..anyone can help me.. 😉
