I have an USB InfraRed connection and the PC suite (new version) works fine (mRouter connects right).
But how can i send midi files from the suite to my phone? It allows only pictures.
I haven't an email access through my mobile so my only means of doing that is via InfraRed.
I have heard some people saying send the file from IR to the mobile. How is that possible? Please explain me step by step. I'm using WinXP.
Thanks.
just activate the infrared on your phone, you'll see the connection icon on the bottom right. Using Explorer, find the file you want to send to your phone, then right click on it. One of the options is "send to IR recipient". Choose this option. Then the file appears in your inbox on the phone.
Alternatively, you can use the "wireless link" option, which should appear on your desktop when the IR link is established. Just browse to the file you want, and "send".
Paul
with ir i know it works but what most people want to know is how to use the same with bluetooth? I can not use my explorer and send files with bluetooth
It works the same way with BT.
Easiest way is to use Psiloc's PC File Manager.
I use IR, and I have never succesfully managed to transfer stuff to/from my phone using Wireless Link (always get device not found error). PC Suite always worked fine for me, and now, PC File Manager works good too, so all my problems are solved 😃
explorer>right click on file>send via IR. Don't go through the PCsuite.
This message proved to be really useful to me!!!!!!!
Jojo
