3650 memory
3 replies · 1,920 views · Started 04 September 2003
Hi all can any1 help ive recently brought myself a nok 3650 and already the phone memory is full what i want to know is there a way i can save games, images etc to my memory card then delete them from the phone memory if so will the games still work through the memory card hope u can help many thanx. 😃
You need to uninstall them from the phone memory and install them onto the MMC the only way to do it easily. I am sure there is a way to just copy files and edit some system and ini files but it will probably take you longer.
I've posted the following reply on another thread:
Use File Explorer or SeleQ. Move the images from c:\Nokia\Images to e:\Images. don't forget to change the memory in use by the camera to the MMC card. (Click on camera->options->settings->memory in use.)
you can do the same with videos and the video recorder.
Right you are. Sorry I was only talking about the apps, there is no simple way of moving them to another folder.
