goodday,
i am using the ir remote system but it does not work
on my Sony TV
its a europian model as i am from Holland
what should i do?
someone told me sometimes a other brand would work
but if i would try every tv device on the phone
i would be busy for years
do yo have any idea
with warm regards,
Faisj
the remote doesnt work with all of my ir devices either. its probably because its a new program and there are still devices yet to be added. try searching the net to find which makes are compatible.
SAbz
[quote="SAbz911"]the remote doesnt work with all of my ir devices either. its probably because its a new program and there are still devices yet to be added. try searching the net to find which makes are compatible.
SAbz[/quote]
damn i was really wanting to use that piece of software
i just tried all devices on my tv
but not one works
i wish you could like scan the ir freq
didn't work for me either.
Works on my:
Hitatchi TV
LG TV
Panasonic Stereo
Panasonic DVD
Panasonic TV
Aiwa Stereo
Doesn't work on my
Kenwood home theatre
Also works on 90% of friend's devices I have tried 😊
It works for me. I've tried it with lots of devices and none have failed. So, I think I can't help here...
my version 0.98 keeps "unregistering" itself. how do i fix this?
[email protected] for registered users 😃
which version are you all using? im using vr 0.97. is there a bush dvd remote on the latest version?
[quote="Anonymous"]which version are you all using? im using vr 0.97. is there a bush dvd remote on the latest version?[/quote]
The only difference between 0.98 and 0.97 is that 0.98 allows you to install the skins that you want, therefore saving space on the 7650.
Psiloc have just released v1.0 with several improvements:
http://www.psiloc.com/?id=prod&nrp=84
Paul
this app is really nice 😃
