7650 became so slowww
4 replies · 1,823 views · Started 10 May 2003
my 7650's log became so so so slow that I fed up with it
it happened suddenly. what is the problem??
MEMORY, for sure. Just try to delete some app. you use not so frequently and If that doesn't work make a HARD RESET.
What app have you installed recently? Some leave IMPORTANT ammount of spaced used when uninstalled. Be carefull. 😃
[quote="MemphisX"]There is always the universal solution of throwing it on the wall...[/quote]
The thing is, ppl usually wants to keep using their phones. 😃
