Hi:
If you install some games/aplicattions on the MMC they don�t work. Only in the phone memory. Will be this situation corrected?
I hope so, otherwise the mmc is usefuless... :x
Hi:
Yeah, these software programs were typically made just for the 7650, before the 3650 was released, and so the software is hardcoded to search for files on C: (phone memory) rather than C: or E: (MMC). Software updates are usually available to fix the problem.
Thanks a lot.
that's true, there are applications that you can only install using device memory and not the memory card. but for sure sooner or later, nokia would also gonna come up with this one. how soon? well, i dont know too! let's just wish that it will be soon on it's way.
mgs has to be installed in phone memory... and those games that uses mgs too
Forgive the ignorance but what's mgs? 😮ops:
an update from Nokia wouldn't solve anything... the problem is in the software itself... the updates must come from the software makers...
