newbie questions bout the 9210i
4 replies · 1,966 views · Started 28 June 2002
hi i am a newbie to this scene
i just git a 9210i and i am having problems from day 1
first problem i dont seem to be able to play ny ,rm or .ram files using real one player some times it just plays the sound other times it just says out of memory
second how am i supposed to play .nim files i tried real one player for that too but it didnt work
third do i really need a memory car
forth i tried listening to .wav files and compared em to the .mp3 ones and the .wav files even when downsampled sound much better than high bitrate mp3's is this normal
thank u all User posted image
oh and i almost forgot is there a way to convert ,rtx files into .rng ones in bulk cause i have a couple hundreds of those<font size=-1>[ This Message was edited by NoS-LiVeD on 2002-06-28 1326 ]</font>
You have the use video player to play nim files. (in extras) you can find some http//www.n9210.co.uk and http//nokia.warlocks.be.
The communicator is mono, and only has 4 channel sound. that's why music doesn't sound as good as it should. If you convert to mono wav files you can get smaller files then usual mp3's and better sound. At least that's my experience User posted image
You don't have to get a memory card User posted image But if you wanna play movie clips and mp3/wavs you'll need one to store them.
Real media sucks on desktop and keeps sucking on the communicator, I only use the nim's. Offcourse that's yours to decide User posted image
Have fun User posted image
Dazler
thnx for the info man
but the only .nim that i got to play is the simpson's 1
i made 3 other and i d/l 2 but they all dont work
i get playback error not found???
also bout the ringing tones ny way to convert em from .rtx to .rng
thanks
UPDATE UPDATE
i managed to play all .nims files now just had to restart the phone
but still bout the ringtones
peace
