Which Bluetooth USB adaptor for Nokia 3650
9 replies · 2,351 views · Started 22 May 2003
Just wondering which USB dongles everyone has hed the best luck with. Any comments or suggestions are more than welcome.
hi,
sitecom usb stick. i have one and it goes. if u need help with them or the soft 2.9.9.x ask me. i will help u.
cya amigappc
[quote="Sting-Ray"]I use an MSI one... called "PC2PC".. works like a charm[/quote]
MSI here too. Haven't have any problems with it. Works great!
I have a nameless (could not find a brand on the box) Y-210. Comes with XTND connect Blue Manager. Problems working in 98SE. Not working much in XP. Granted I am saying about it working with PCSuite. As far as recognizing the phone and sending files using the Blue Manager it works in both.
I've got Hawking Technology USB Bluetooth adapter from Amazon.com for $30.99 including shipping. It works fine after some IRQ problem fixing via Nokia Tech Support.
The one I have is identical to the Acer bt device. (same chipset) Works like a charm 😊 (apart from minor details, that I have found out others have as well)
