Lo all new around here :)
6 replies · 1,578 views · Started 23 May 2003
Just got my 7650 😊
dont spose any1 knows how to get irc and msn on the fone for free do they ? (dont like the idea of paying for something I dont know if I can use it properly yet).
I'm slightly wary of paying for apps particularly since I tried the trial version of Wireless IRc and couldn't get connected to any server, not even quakenet after configuring it all.
Thanks for any help 😊
[email protected] or do NOT post here 😃
j2k edit: do not ask for warez please. Buy the software.
For free MSN try www.tipic.com
sorry I didnt mean warez.
I having problems with trial of wireless IRC trial version I can't connect to servers.
It resolves the address ok, just says Disconnected (-33) all the time 😞
This -33 error reminds me of a similar problem of not being able to connect an application to the internet.. In that case all I had to do was to use a WAP GRPS connection profile instead of a "normal" one for general internet use. In case a different connection profile is required for your GSM provider, too, try using either of them although the General Internet connection profile is probably what you need with Wireless IRC.
