ok i got the gprs settings down for my phone. Now the problem is, ever time i try to connect it tells me that the gateway is not responding. wtf does that mean? i called customer support and they told me that everything should be fine! im about to give up on this gprs thing! someone please help. also, where do you put the settings for MMS on the 3650? i went under settings on the message icon but i couldnt find it. thanks! PEACE :cry: 😮ops:
GATEWAY NOT RESPONDING! HELP!! (CINGULAR)
To define an access point for MMS you use connections in settings. Same place where you define a GPRS access point. The settings are different though.
As far as your GPRS woe 1. did you activate that service (trivial but happened to me). 2. Cingular is full of it most of the time. I had so many problems with them until AT&T wireless in CA started providing GSM service.
