Does any MMC card work as extra memory
which does you recomend
How about
Viking MultiMediaCard 64MB
Sven-Olov
Flash memory mmc
Any MMC should work. Make sure you get MMC (MultiMedia Card), not SD (Secure Digital) card, though. Remember to format it on the phone before you start using it.
But as far as the MMC card working as extra RAM I believe it does NOT. Therefor the only RAM you have is the internal phone memory. (Please correct this if it is wrong). Because of this it is wise to install as much as you can on the MMC card so that you have the most RAM available to run programs.
I agree with you Kirill. The MMC is just for saving your apps and data.
Any MMC will work... from 16mb - 128mb... the 256mb is still a question
