Have nokia 3650 got GPS program?
I know one guy,who had installed Mini GPS,and he has got SYS error,contact the retailer.But you shouldnt worry,IVOMIR has got MINI GPS,and all is ok with his 3650.
I am thinking about navigation system like i cars it have a map and shows where we are
Nokia 3650 does not have the GPS hardware,miniGPS doesn't have anything to do with real GPS,so the answer would be no.
[quote="jimmy-floyd"]I know one guy,who had installed Mini GPS,and he has got SYS error,contact the retailer.But you shouldnt worry,IVOMIR has got MINI GPS,and all is ok with his 3650.[/quote]
AIUI, the "Contact retailer" bug affected a range of PsiLOC products (especially irRemote), as there was a fault in the PsiNT.dll file, which was set as a "Recognizer" (like an autoexec.bat file on a PC), meaning when it loaded, it crashed the phone. I believe newer versions have a fixed DLL file, which no longer causes the problem.
And, it's ".SIS" (Software Installation Script (thanks Ewan :P)), not ".SYS" (System File) - two totally different file types 😉
(I know in this instance you're referring to "System error", but quite a lot of people say .SYS instead of .SIS, just pointing out the difference 😉)
Cheers
THANKS,you have explained all,thanks again.Yes i minded SIS error.
www.wayfinder.com
a REAL gps system 😊
This is great!But why does it have to be operator and GPRS dependand?If i want to have the latest traffic information,then,ok but what if i just want to know where the hell i am?Can i do that with just the software installed on the phone?
Probably because the complete map information will not fit even on a 1GB MMC. I am making this assumption because the map for the entire US barely fits on a DVD for the car nav system.
On a sad note Russia is once again not included. Although we finally have a Palm based GPS navigation system developed.
