Sometimes my n3650 ringtone sounds properly, but sometimes it rings
very very slow (almost mute). Anybody facing similar problem?
Is there any bug in N3650?
Is there any bug in Nokia 3650?
I have the same problem. Don't now why...
well, it's a common problem but I personally haven't experienced that.
I have not had that problem but sometimes when I have a ringtone assigned for a specific profile a different ringtone will ring when I get a call or it will start out with my assigned ringtone and then switch a few seconds into it to another ringtone that was not supposed to ring. Has this happened to anyone?
Yehh ! i have the same prob. The solution to this is to swith to outdoor profile. And turn the vibration mode on.
You can also increase the volume of the using the ringtone studio.
But all this doen't make a huge difference.
I seriouslly feel Nokia should do something about this prob.
List of Bugs in my Phone :-
1. Ring tone Volume low.
2. Video Recorder does not open from the Right/Left key Selction
3. Most of the games of 7650 does not run , because of memory or
system error.
4. Message Application hangs frequently.
5. The phone is quite slow.
the video recorder is a bug alright.
But the apps for 7650 not running on 3650 isn't... those app were just made to be saved on the phone memory. Some won't run if you install the app in the MMC.
Apps for 7650 work if you install them into main phone memory, some will work from the MMC. But since the 7650 has no MMC capabilty the apps for it were written without support for it.
