Saving Images after Zooming In
11 replies · 2,512 views · Started 28 May 2003
Is it possible on the 3650 to save an image to phone memory or MMC after you have taken the image (with the built in camera app that comes with the phone) and using the phone's built in features zoom in on the image. I guess the easy way to explain is can you capture an image that you have zoomed in on or do you need to by a third party app (or freeware)? Any helpful comments are appreciated.
I don't think you can save the picture that you have taken with your built in app and you zoomed in for viewing.
If you want to zoom, buy third party apps like Camera Fx and Photographer.
Have you used either of these? If yes, which would you suggest? Has anyone else used either programme?
Camera FX has lots of features and effects... but the quality isn't that good. Photographer is much better (as what I've read from people here)... I've only tried Camera FX and quality is really bad.
I've tried CameraFX - did not like it. Today, I tried Photographer 2.2 - Great! Easy to use, simple features. I intend to buy it. I hope this review will help you. Anyway, they both have trial versions. Download, install and try them both for yourself.
you should be able so save the zoomed pic by taking a screenshot (view pic in fillscreen)
There are many tools to capture screenshots.. e.g. seleq
[quote="Anonymous"]you should be able so save the zoomed pic by taking a screenshot (view pic in fillscreen)
There are many tools to capture screenshots.. e.g. seleq[/quote]
nice suggestion...
