I just a tmobile 3650 and i was wondering how to know the firmware version in my phone. Also i just wanted to know if i should get an mmc reader or an infra red cable and or a bluetooth dongle. I need help pls!!!
How to check firmware # or version
Version: *#0000#
Connection Recommendation: Bluetooth
I use IR,but also recommendate BLUETOOTH.
Cheapest option is a card reader. Mine cost under �10 and is very easy. Just move files around the same as on yr PC.
The disadvantage of the card reader is that you will not be able to install apps on your phone through the card reader. If you have File Manager or similar it is not a problem though.
Bluetooth and IR is esentially the same, except bluetooth is faster and does not require alignment of optical elements.
just want to ask if i want to upgrade my firmware version, which one is the best and how to upgrade my firmware... mine is V2.0536.02 thanks...
If ur phone still under warranty (authorized of Nokia), then take it to nearest NSC. The cost it'll be free. If the warranty has expired but authorized of Nokia, then discount 50%. If from black market, then the cost $10.
Backup ur phone to MMC or PC Suite 1st b4 bring it to NSC or ask the NSC to backup ur phone (Contacts, data, notes.. etc). Remember, they don't need ur SIM & MMC.
Good luck 😉
