3650 message prob.
10 replies · 2,361 views · Started 29 May 2003
i can't seem to send messages...
when i try to compose all i get is numbers
how do i switch and get the little abc in the corner?????
I've read people using WildSkinz having such problems. Did you install it recently, by any chance? If so, see what happens if you uninstall and power off and on your phone again.
yes its because of wildskinz....
you have to disable wildskinz first (in its settings) then you have to reboot your phone.....after rebooting, remove wildskinz using app manager, reboot again and everything will be back to normal.......
It's a program that enables you to have different skins for your phone... it's also a program that makes your phone go crazy..
[quote="ST@RR"]it's also a program that makes your phone go crazy..[/quote]
hence the name... wild skinz =)
guess I'll wait for tamedskinz... 😉
i already uninstalled the wildskinz. but before i uninstall i did not unable it.
:: but my phone is still not working after it was uninstalled.
i cannot type character.
or .. is there any more file of wildskinz in the phone to be deleted??
any ideas plz??
thankz
looks like since you did not follow instructions precisely you need to 7370 your phone. Or you can try reinstalling WildSkinz then removing it properly. Try that if not then buy buy data.
