A prob with my supermob...!
5 replies · 1,806 views · Started 29 May 2003
My loudspeaker function won't work! 😞
When I press the button on the side,it says that it's deactivated right away!
Sometimes it's working for half a sec,but not any long.
Maybe it's something wrong with the sensor....
Do anyone have a way to fix this a little quick without bothering the nokia guys?? :roll:
You pressing the button while the phone is near your head? ( or something else.. ) Since the 7650 has a proximity sensor, it also has a function that disables the loudspeaker when you put the phone to your ear..
...or when you pass your finger in front of the sensor, just after you pressed the loudspeaker button 😉
it may be an error caused from an application on ur fone. i had the same problem, so i did a hard reset and it started working again. might work for u to, worth a try, save ya havin to go to a nokia service centre.
OK in view of the fact that u reminded me that u hav brains, this mite seem stupid.......... but on the N7650 face, there are two sensors... the single circle type thing on the right and the two circle type thing on the left.... for loud speaker.... its the two circle type thing on the left. the other one is a light sensor.
