Basically I have a Nokia 3650 on order. It is about to be delivered some time next week. Its' fair to say I am fairly dense when it come to converting video/audio to my phone.
Is there any way someone could provide me with simple (step-by-step) instructions of:
How to listen to mp3's on my 3650 (i heard that was possible)...
How to use mp3's as ringtones...
How to play movies (mpeg's etc) on my 3650...
I have Bluetooth capabilities. I hear you need a program called mp3go as well. I have no idea where to get this or how to use it. I will greatly appreciate any help. Remember keep it simple.. 😮ops:
Thank You
1)YOU need MP3go to listen to mp3 ;3)use helix produces .e.t.c
thanks for replying, but not very speicifc. Where do i get mp3go. Can i get it free? Where/what is Helix?
Just search through the forum.
youll want to get FExplorer to browse your phone. its a must
i think you have to pay for mp3go, not sure how to use them as ringtones though.
mp3go isn't free... I forgot the site exactly so better search for it...
mp3's cannot be used as ringing tones... you can only use WAV files.
FileExplorers may also come handy since our phone cannot open mp3 files since it doesn't support the format so, you need to move the mp3 file to the correct folder manually... This is only if you send mp3s directly from PC to phone using bluetooth. The mp3 goes to the inbox.
If you use Nokia PC Suite to transfer MP3s to your phone(with file conversion enabled), they will be converted to WAV files that can be used as ringtones.
You can use .mav AND .mid files for you ringtones and message tones.
I was wondering how do you put music or get music sent to your phone(3650). I'm kinda stumped please help me I have realpalyer and MP3Go on my phone any body please.
Send me an email @ [email][email protected][/email] Thank You
