7650 to an mp3 player..is it possible??
4 replies · 2,155 views · Started 01 June 2003
i've seen an app 4 7650 that can play mp3 files...but 7650 only have 4mb of memory...how come can i store my mp3 to my fone and play it???plz help... 😊 😊
Yes, but you can only store the MP3's in the phone memory, so there won't be many tracks you can have on that phone.
On phones with MMC (MultiMedia Card) memory cards, you can store them on the memory cards. Currently that means the Nokia 3650.
ahmmm.....tnx for the info....may i ask, is there no memory extender for a nokia 7650!???an application or sumthing!???and r u familiar w/the app "spacedoubler..."?does it really work!???
I used to hav a N7650 and had tried SPACEDOUBLER.... it dosnt actually "double" the memory but what it actually is is a sort of compression software.. it compresses the progs and apps on ur fone wen u r not using them so as to giv u a bit more space for other stuff. BUT the prob is u hav to make sure tht u hav enough free memory left on ur fone to uncompress the apps b4 u can use them then once u r done with it it compresses them again. PS- if u are deleting the software make sure u hav uncompressed everything first.........i had forgotten to do tht so had to re install it.... un compr... n then delete again......................................but as for the mp3 part it really is no point u wont hav enough memory.
Pal, forget about it. 7650 has not enough memory and it's MONO so...
I tried every simgle format GSM 6.0, PCM, MP3 and all them sound like shit in the 7650. Sorry....
