Bluetooth is making me crazy
16 replies · 3,516 views · Started 02 June 2003
For the past week i been trying to figure out this bluetooth connection, i have a penblue usb dongle bluetooth connection, trying to connect it to my phone, and so far i havn't had any luck, i sware i put in about 15 hours trying to figure this out and i dont know what else to do. I bought this penblue usb dongle cause someone on this forum reccomended it. It seems like my phone reads the bluetooth on the computer but the ladder does not read the phone and i cant seem to make a connection.
I'm beggin anyone PLEASE HELP ME, does anyone know of a bluetooth help line phone #, cause i give up i cant figure this out and im going crazy...any help is appreciated THANK YOU...shaolin
What brand are you using? Mine is MSI bluetooth and it works just fine. Well for my bluetooth I just installed the application that comes with the hardware first then I just add to the wizard a new serial connection for my cellfone then when it's done try pairing your pc and your fone first and then make it as an authorised so it will not ask you over and over again if you want to pair those devices. Then vice versa authorise your phone also to your pc then walla that's all. Ah I rememeber then click your new serial connection which you made before doing all that stuff. That's it!
Anyway hope I've been some help to your prob
Hi
I've posted this on a different thread, and I'm not sure if it's what you need, since apparently your phone can find your comp, but not the other way around... but I'll post it here anyway:
Go to "My Bluetooth Places", "Entire Bluetooth Neighboorhood", "nokia 3650", right-click, "discover available services", right-click "connect bluetooth serial port". That should do it.
or
Find which is your local services BT serial com port number (com 5 on mine), and your client applications serial com port number (com 4 on mine).
Open mRouter, disconnect all ports.
connect your client applications serial com port first
after about 3 seconds connect your local services serial com port.
you can find your BT settings by right-clicking your bt icon on the bottom right corner of your monitor, near the clock and going to "advanced configuration"
complicated, but it works for me (a lot of trial and error on this one...)
cant beleive i got it to connect but now i got another problemo...by the way thanx for everyones help(i uninstalled then reinstalled the new drivers and it worked).
Ok now my phone is making the connection with my computer, my problem is pairing my phone to my comp, on my computer it ask for a pin code then i create one(which i suppose to right, i just type in nokia3650) and it makes the connection with my phone, my phone then ask me for the password for my computer, and i have no clue what the damn password is to connect me, i tryed tons of simple codes but nothing works, how do i find out my computers bluetooth password, thanx any help is much appreciated....shaolin
any password will do... just make sure that they are both the same on the PC and phone... you can do like 0000.
I understand the passwords have to be the same, the problem is i dont know what the passwords are, how can i create new passwords so i actually know them, who do i contact or where do i go to find out how to do this? I mean theres has to be a place on my computer that stored my password or something.
You will make the password. When pairing, it asks for the pin right? Choose any number... and your phone also asks for the PIN right? Just type the same number.
To explain in a different way.
YOU create the password at the time you device asks for it. In other words you are not asked for a password but are asked to make one up in order to pair the devices. Not very well worded at all by the creators but hey. This is only to make sure you will not connec to an unauthorized BT device in range.
aight im making progress here, i figured out how to change my password for my comp bluetooth connection and used the same for my phone and it paired devices, now i can send ringtones and images to my phone from this cd i ordered from ebay with tons of nokia 3650 ringtones, images, games ect.
Now I have to figure out how to send the games and apps to my phone, because when i goto send to, bluetooth, nokia3650, it dont send it to my phone like the ringtones it says i have to do it some other way, any suggestions how to do that?
Thanx...shaolin
Easiest way. Install PC Suite.
If you can't get it to work with PCSuite. Email the FExplorer (freeware) to your phone and then use it to open and move files around from your inbox that you send to yourself.
what does it tell you? coz I don't use PC Suite... I just beam my apps and games directly to my cellphone and everything works fine.
good news, i can download games and apps to my nokia3650 from my comp via bluetooth now(thanx to all yours help), now my next project is getting pc suite to work because for some reason it says to connect my phone to my comp when its allready connected, but i guess i'll figure it out in time. Thanx again people....1luv...shaolin
heyy all,was readin thru 2 replies.n u all made sum one 1 very happy...im not tho!!!! stupid bluetooth.
lol
i got a bluegear dongle, windows 2000,and using pc suite latest version.
what is the best software 2 use, and where can i get that from????
plz help....
marky mark
lol
plz help....
marky mark
